ALIWEB20 Posted November 25, 2025 Report Share Posted November 25, 2025 Hello I have a simple 2011 Ford Edge that after replacing the spark plugs, it draws air from the manifold and the engine draws less air. The mechanic said the problem might be with the throttle valve and he still hasn't been able to fix the problem. The main problem is that the engine runs at idle and makes a hissing sound every few seconds and the engine runs poorly. It seems like the car is short of breath and the hissing sound gets louder when you give it gas. Please help me, what should I do? Quote Link to comment Share on other sites More sharing options...
1004ron Posted November 25, 2025 Report Share Posted November 25, 2025 32 minutes ago, ALIWEB20 said: Hello I have a simple 2011 Ford Edge that after replacing the spark plugs, it draws air from the manifold and the engine draws less air. The mechanic said the problem might be with the throttle valve and he still hasn't been able to fix the problem. The main problem is that the engine runs at idle and makes a hissing sound every few seconds and the engine runs poorly. It seems like the car is short of breath and the hissing sound gets louder when you give it gas. Please help me, what should I do? Welcome. What you've written doesn't give us much to work with and suggest a fix and based on what you've written it doesn't look like you DIY. Any suggestions here we expect that you'll convey to what appears to be an inept "mechanic" which isn't ideal - it would be far better to seek the services of a local reputable real mechanic. Quote Link to comment Share on other sites More sharing options...
