Blk22Edge Posted November 28, 2025 Report Share Posted November 28, 2025 It seems to me like my transmission is bucking & shuddering at slow speeds. From what I'm seeing it may be due to the torque converter. I've already done a drain and fill on it and used Ford's fluid for it so there wouldn't be any guessing on if it was right or not. Is it possible that the transmission is already failing? My Edge has 68k miles on it and I did the first drain & fill at 50k miles. Any suggestions? 2022 Ford Edge SEL 2.0 EcoBoost 68,000 miles. Driven in upstate NY. 1 Quote Link to comment Share on other sites More sharing options...
ford07 Posted December 29, 2025 Report Share Posted December 29, 2025 (edited) This most likely corresponds to a torque converter shudder, a known problem with this transmission and not a sign that the gearbox is failing, especially at 109,000 km. The fact that the oil change was done late may explain why the new oil hasn't completely resolved the issue. Mini Militia App Lock Edited January 9 by ford07 1 Quote Link to comment Share on other sites More sharing options...
STBEAST Posted December 30, 2025 Report Share Posted December 30, 2025 It could be something as simple as a software update or reprogramming. Quote Link to comment Share on other sites More sharing options...
Steve JC Posted January 8 Report Share Posted January 8 Just had the transmission replaced in my 2022 Titanium at 67K miles! Quote Link to comment Share on other sites More sharing options...
edgeidiot Posted January 8 Report Share Posted January 8 Was your transmission serviced (flushed or drained and refill?) Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted 9 hours ago Report Share Posted 9 hours ago (edited) Old fluid is a known cause,, but you've already addressed that. (Change at 30k — 40k intervals.) At 68k you're past the 60k warranty. Have you checked for codes? P0741 is a code which often displays when this condition occurs. (Torque converter clutch solenoid performance). TSB 21-2389 addresses the problem of shuddering or jerking at speeds up to 35 mph. (Doesn't occur above 35 mph.) Is revises the software in the PCM. (Changes when the xmission shifts.) . Edited 9 hours ago by enigma-2 Quote Link to comment Share on other sites More sharing options...
