Jeanna Posted December 27, 2025 Report Share Posted December 27, 2025 My daughter’s door keypad is staying lit all the time. It does not work. Now the lights are flashing 3 separate times and locking doors even if the key is inside. I have tried pulling fuse # 9, #10 and #11 under dash with no results. Can anyone suggest anything else? She is going to take it to get it looked at but I don’t want it to drain the battery before then. Thanks Quote Link to comment Share on other sites More sharing options...
dabangsta Posted December 28, 2025 Report Share Posted December 28, 2025 Should be the dual micro fuse 10/11, that is also for the liftgate. I had to remove the door panel and unplug one of these, it would turn on the lights all night, it got damaged due to water intrusion. Quote Link to comment Share on other sites More sharing options...
