in over my head Posted January 2 Report Share Posted January 2 Changed water pump on my 2008 ford edge limited got it all back together now it just cranks no start it trys to start but don't hooked up to scanner it throwing 17 codes from not connecting to pcm to low battery voltage to anti theft has engine disabled! What do I do ?? 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted January 3 Report Share Posted January 3 What are the 17 codes you mention? Most likely the valve timing is not correct. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted yesterday at 11:19 PM Report Share Posted yesterday at 11:19 PM Guessing.. About the only thing that comes to mind that's electrical and related to changing the water pump & can affect starting is the cam/crank position sensors. (Plugged in, broken wire?) Quote Link to comment Share on other sites More sharing options...
