sc00by Posted Monday at 05:59 PM Report Share Posted Monday at 05:59 PM (edited) Greetings, The turn signal in my front driver's side head lamp went out. Looking at the assembly, it appears that there isn't a bulb to replace, and the entire housing needs to be replaced? I am seeing two different part numbers listed and am curious if someone can help me locate the correct housing. On for parts giant I am seeing: KT4Z-13008-AZ for $578 or KT4Z-13101-C for $1801 I used my vin to locate these parts but am curious why there are two different SKUs with varying part cost. Any help? Edited Monday at 06:00 PM by sc00by 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted Tuesday at 05:38 AM Report Share Posted Tuesday at 05:38 AM KT4Z-13101-C is only a partial headlight housing. It does not include all parts. It is missing the Lighting Control Module that is the metal box underneath the headlight. KT4Z-13008-AZ is the composite headlamp assembly. It includes the Lighting Control Module. Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted Tuesday at 05:42 AM Report Share Posted Tuesday at 05:42 AM 11 hours ago, sc00by said: Looking at the assembly, it appears that there isn't a bulb to replace The headlights that you listed are both non adaptive headlights. These headlights should have a dual filament halogen amber bulb. Front direction indicator: WY21W (21 Watts). Quote Link to comment Share on other sites More sharing options...
sc00by Posted Tuesday at 12:47 PM Author Report Share Posted Tuesday at 12:47 PM Mine do not have a spot for a replacement bulb, it is all integrated as one unit. Couldn't I reuse the light control module? 2 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted Wednesday at 01:35 AM Report Share Posted Wednesday at 01:35 AM (edited) What do your headlights look like? Do you have the adaptive headlights? Both part numbers that you listed are for the non adaptive headlights. The non adaptive headlights use halogen bulbs that are replaceable. The adaptive headlights use led turn signals that are not replaceable. Edited Wednesday at 01:36 AM by Wubster100 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted Wednesday at 01:36 AM Report Share Posted Wednesday at 01:36 AM Quote Link to comment Share on other sites More sharing options...
sc00by Posted Wednesday at 01:39 AM Author Report Share Posted Wednesday at 01:39 AM 2 minutes ago, Wubster100 said: Do you have the adaptive headlights? Both part numbers that you listed are for the non adaptive headlights. The non adaptive headlights use halogen bulbs that are replaceable. The adaptive headlights use led turn signals that are not replaceable. yes they are full LED which is why I was looking at replacing the whole unit. They are not serviceable. it also started working again so idk wtf to make of it. 2 Quote Link to comment Share on other sites More sharing options...
STBEAST Posted Wednesday at 02:28 AM Report Share Posted Wednesday at 02:28 AM Yes, they are not serviceable, you have to replace the whole thing! Expensive and sad. I think you should check all the plugs/connectors and grounds. unplug and plug back in. That will 'clean' the contacts. You might get lucky. 1 Quote Link to comment Share on other sites More sharing options...
sc00by Posted Wednesday at 11:58 AM Author Report Share Posted Wednesday at 11:58 AM 9 hours ago, STBEAST said: Yes, they are not serviceable, you have to replace the whole thing! Expensive and sad. I think you should check all the plugs/connectors and grounds. unplug and plug back in. That will 'clean' the contacts. You might get lucky. Yeah, that gets back to the original post: What part# would I need? Quote Link to comment Share on other sites More sharing options...
STBEAST Posted Wednesday at 04:08 PM Report Share Posted Wednesday at 04:08 PM Because there seems to be some confusion regarding the correct part number, I would go to your local Ford dealer and make sure you get the correct number. Quote Link to comment Share on other sites More sharing options...
