sc00by Posted January 12 Report Share Posted January 12 (edited) Greetings, The turn signal in my front driver's side head lamp went out. Looking at the assembly, it appears that there isn't a bulb to replace, and the entire housing needs to be replaced? I am seeing two different part numbers listed and am curious if someone can help me locate the correct housing. On for parts giant I am seeing: KT4Z-13008-AZ for $578 or KT4Z-13101-C for $1801 I used my vin to locate these parts but am curious why there are two different SKUs with varying part cost. Any help? Edited January 12 by sc00by 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted January 13 Report Share Posted January 13 KT4Z-13101-C is only a partial headlight housing. It does not include all parts. It is missing the Lighting Control Module that is the metal box underneath the headlight. KT4Z-13008-AZ is the composite headlamp assembly. It includes the Lighting Control Module. Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted January 13 Report Share Posted January 13 11 hours ago, sc00by said: Looking at the assembly, it appears that there isn't a bulb to replace The headlights that you listed are both non adaptive headlights. These headlights should have a dual filament halogen amber bulb. Front direction indicator: WY21W (21 Watts). 1 Quote Link to comment Share on other sites More sharing options...
sc00by Posted January 13 Author Report Share Posted January 13 Mine do not have a spot for a replacement bulb, it is all integrated as one unit. Couldn't I reuse the light control module? 2 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted January 14 Report Share Posted January 14 (edited) What do your headlights look like? Do you have the adaptive headlights? Both part numbers that you listed are for the non adaptive headlights. The non adaptive headlights use halogen bulbs that are replaceable. The adaptive headlights use led turn signals that are not replaceable. Edited January 14 by Wubster100 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted January 14 Report Share Posted January 14 Quote Link to comment Share on other sites More sharing options...
sc00by Posted January 14 Author Report Share Posted January 14 2 minutes ago, Wubster100 said: Do you have the adaptive headlights? Both part numbers that you listed are for the non adaptive headlights. The non adaptive headlights use halogen bulbs that are replaceable. The adaptive headlights use led turn signals that are not replaceable. yes they are full LED which is why I was looking at replacing the whole unit. They are not serviceable. it also started working again so idk wtf to make of it. 2 Quote Link to comment Share on other sites More sharing options...
STBEAST Posted January 14 Report Share Posted January 14 Yes, they are not serviceable, you have to replace the whole thing! Expensive and sad. I think you should check all the plugs/connectors and grounds. unplug and plug back in. That will 'clean' the contacts. You might get lucky. 1 Quote Link to comment Share on other sites More sharing options...
sc00by Posted January 14 Author Report Share Posted January 14 9 hours ago, STBEAST said: Yes, they are not serviceable, you have to replace the whole thing! Expensive and sad. I think you should check all the plugs/connectors and grounds. unplug and plug back in. That will 'clean' the contacts. You might get lucky. Yeah, that gets back to the original post: What part# would I need? Quote Link to comment Share on other sites More sharing options...
STBEAST Posted January 14 Report Share Posted January 14 Because there seems to be some confusion regarding the correct part number, I would go to your local Ford dealer and make sure you get the correct number. Quote Link to comment Share on other sites More sharing options...
