LuisT863 Posted January 19 Report Share Posted January 19 Hey guys! After my work vehicle recently gave out on me at a little over 300K miles I decided to pick up a 2015 Edge sport with 110K miles on it. Extremely clean condition, clean Carfax etc etc. Well I didn't do my research enough because it came with the dreaded leaking oil pan. After some research it doesn't look like it's too bad of a job to do myself. But I have a more concerning issue I need help with. The coolant reservoir is getting low at a pretty fast rate but I can't find any external leaks anywhere. I just did an oil change this weekend and the oil doesn't look milky like you would expect if it was going in there. I don't see any smoke coming out of the exhaust other than on a really cold morning. Were there any known issues with this for this model? Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
1004ron Posted January 19 Report Share Posted January 19 Welcome, I don't recall seeing any typical coolant loss issues with the 2.7L I would pull the spark plugs and look for signs like a very clean one. Also, Autozone rent out the equipment to sniff for combustion gases in the coolant reservoir with the engine running, and if none of that reveals anything then a compression and leak-down test. Quote Link to comment Share on other sites More sharing options...
LuisT863 Posted January 20 Author Report Share Posted January 20 22 hours ago, 1004ron said: Welcome, I don't recall seeing any typical coolant loss issues with the 2.7L I would pull the spark plugs and look for signs like a very clean one. Also, Autozone rent out the equipment to sniff for combustion gases in the coolant reservoir with the engine running, and if none of that reveals anything then a compression and leak-down test. I appreciate the sound advice. I hope I did not make a mistake here by purchasing this. It runs so well that I am having a hard time thinking it's something serious. Quote Link to comment Share on other sites More sharing options...
