Marced Posted February 8 Report Share Posted February 8 2016 ford edge, 133k miles. Took it into a dealership because the back was grinding. Turns out it was an issue with the rear differential. After I brought it home, it started giving me problems. This is what it's doing: - Acts like it’s starving for fuel and doesn’t shift correctly. Rpm’s are different every time you drive it. There is a delay in acceleration. - It will show no key fob detected even with new batteries. - The back hatch will close then pop back open. - The Bluetooth will disconnect and sometimes it won’t reconnect. - All symptoms are sometimes. - Dealership did a master reset and everything worked perfectly for a bit then everything started happening again. I had an open recall and they started the update and unplugged it while it was updating and it left it saying incomplete. I had another Ford dealership finish it. It didn’t help. - I did have a mouse chew up my windshield wiper hoses to the reservoir and a wire that went to my air bags to the front bumper sensor. Maybe they have chewed thru something else? - Computer? PCM? - No codes when plugged in. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted 10 hours ago Report Share Posted 10 hours ago Did you ever get this fixed? Quote Link to comment Share on other sites More sharing options...
