How To Play USB Tracks In Order 2024 Edge SEL
My 2024 Edge SEL does not have a CD player...none do.
We have a ton of audiobooks on CD that we listen to when traveling.
I tried an external CD player but it would not work in the Edge.
Sooooooooooo,
I copied 25 audio books from CDs to flash drive. converting to MP3 format, FAT 32 filing system on the thumb drive. USB 2.0
When inserted, the files do not come up with the same structure as the USB drive displays on my PC.
I do NOT have random play enabled.
The playback started automatically with a book way down the list.
I manually advanced the tracks, but, after disc 3 (out of 5) it moved to another book!
But I cannot figure out haw to play the tracks in order.
I have played with the repeat setting, and sometimes the book will move to the nest track, but then i twill jump 2 tracks the nest time....
When playing with this before, somewhere I had come across a menu of settings, one of which was "Play All"
That had worked, but I am not able to find that menu now.....
SOMEWHERE there is a menu...............
How does the USB device interface with SYNC ??
Thanks for any help......
Edited by Ronno6
Additional infio
  • Ronno6 changed the title to How To Play USB Tracks In Order 2024 Edge SEL
