MP3 Bluetooth Playback Eliminate Cell Phone Navigation?
I believe that Sync requires the audio device to use Advanced Audio Distribution Profile (A2DP) for communication.
If your MP3 player is a basic version, the car's system may simply refuse to recognize it as a valid audio source.
One way around this is to interface with Sync via a FM transmitter plugged into your players headphone jack or through BT. Pick up the audio  on FM.
$10 on Amazon,  not out a bd if it doesn’t work.
https://a.co/d/0e0mcESE
Only fly in that ointment is that we listen to the AB's while travelling.....an FM frequency not in use here
may have stations come and go as we traverse the territory.......
That could prove to be a distraction while driving.
I may have confused you. The FM adapter takes the music from your source and then you tune to a specific FM channel and the adapter plays to that channel. (Just another method to play audio via a wireless connection, to your radio.)
Posted (edited)
No, I understand what the device is and does. But, if your radio is tuned to the frequency of the adapter, will it not be interfered with if there is a local FM station on the same frequency?
The ad states:  "QUITE EASY USE - Insert the 3.5mm plug into your device just as you would a pair of headphones. Turn on the transmitter and set it to an FM frequency that's not in use in your area. "
While travelling, FM stations come and go.....
Edited by Ronno6
The FM adapter can tune as low as 87.5mhz There is no FM station on that frequency.
The lowest freq. for an FM station is 87.9. There are only 2 stations on that freq., both in California.
Won't be a problem......
But I think an audio cable into USB will work.
