Spikeit Posted March 13 Report Share Posted March 13 I recently replaced the a/c compressor with a well known brand. I didn't disturb any wiring except to hook up the provided wiring adapter from the new compressor to my oem plug. I've gotten some freon in it but no matter what I can't get the ac clutch to engage. I've swapped relays with no luck, all fuses are good, checked wiring continuity from the relay panel to the compressor and for power TO the relay panel and all are ok. What am I missing??? The ac worked great until I swapped the compressor and only did so because the old compressor started leaking oil from the rear cover and yes the bolts were as tight as could be but the leak continued. Any thoughts/ideas anyone? TIA Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted March 17 Report Share Posted March 17 Most likely stems from low refrigerant pressure. Is the system presured properly? If the pressure is outside the safe range (30–40 psi on the low side and 200–225 psi on the high side), the compressor will NOT kick on. Although unlikely, couple of other possibilities include a blown fuse or malfunctioning pressure switch. Check fuse #35 in the power distribution box (in engine compartment.) My guess is you didn't pressurize the system sufficiently (you stated "put some freon in it".) Quote Link to comment Share on other sites More sharing options...
Spikeit Posted March 19 Author Report Share Posted March 19 I apologize because I should've included that. Honestly my in-law did the gassing so I'll ck with him tomorrow and see what he left them at OR I'll hook up my gauges and see. He told me but it's been a day since so I can't remember. Age definitely has it's minuses and having trouble remembering is one. Thank you very much for responding and I will let you know the readings tomorrow. Have a good evening Quote Link to comment Share on other sites More sharing options...
