RodD Posted April 25 Report Share Posted April 25 Hi Everyone! 2011 Edge, The shifter will not go back into park, I can manually place the vehicle back into park under the hood at the transmission and it will register in park. I can then shift it into drive once but then it ill not go back into park using the shifter. Thoughts and ideas as what needs to be replaced? Thanks! Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted 14 hours ago Report Share Posted 14 hours ago Could be a broken shift cable bushing (theres a Recall on this.) If the shifter feels loose or disconnected and does not change gears properly, the The plastic bushing at the transmission end of the cable has broken. (This is a known issue covered by NHTSA Recall 22V-413, and affects 2011-2014 Ford Edges.) the fix is to your dealership to have the bushing replaced for free. Quote Link to comment Share on other sites More sharing options...
