Sync 2-3 conversion nav error
So I did the sync 3 upgrade, updated to 3.4.... latest release,
After messing around for a few days, got the proper as built from Dan.
Everything works as it should, but on most starts I get the nav fault, press ok, a few seconds later nav starts working.
Tried 2 amazon antenna.
Is this an antenna issue or an issues with the other GPS antenna for the dash?
If it's an antenna issue, what are you doing to resolve this? Where from or which vehicle.
I'm willing to extract one at the Wreckers.
I've got under $200 Canadian in this so far, so we'll worth it
