Blinker
maggie'sedge2008
Today when using my left blinker, the right side blinker blinks normal, but the left blinker blinks faster...
When putting on the brakes, the left back light does not work. I do have brake lights on both right and left.
Would this be a bulb issue or maybe a fuse issue?
-Maggie
Bulb. The blinker element is most likely burnt out.
Even thou you do lose me when you say you have brake lights on both sides but then you also say the left back light doesn't if you apply the brakes. So which is it. Or are you saying you have tail lights on both sides? If that is the point then yes the brake light element is burnt out.
agreed- bulb
