Rear view mirror loose on 2009 Ford Edge
I too have a rear view mirror with sensors installed on my Scorpio. I'm able to do a very close and tight parking when required.
As you come closer you can't see the rear bumper edges since the camera, though having a wide angle lens is normally fitted in the center. Secondly. if you observe, that all cars' front have a curved design with the bulge in the center tapering off to the sides. So, the camera enables you to see the front bulging part thus making a tight parking easier.This reverse sensor beeps and has LED display which changes as it nears an object.
It is very easy to install and the sensor sits behind the bumper so there is no need to drill holes in it. Connecting power is as simple as attaching to one of your reverse lights. It comes with full instructions and is in perfect working order.
