Headlight Switch
Dali555
I'm trying to remove the headlight switch so I can tap into the wiring. Anyone know how? Or even that side panel that feeds air to the driver side window on the left of the dash when the door is open?
Thx in advance,
Marc
I figured it out in case anyone searches this topic.... the side panel, just use a flat head screw driver and pry it out. The switch can then be pushed out from behind. Very simple, everything is held in by clips.
