Easy entry (seat) and transmission o/d switch not working.
weasel
I haven't posted on here in quite a while mostly due to the fact that everything on my 08 Limited has been working quite well until recently. A couple of weeks ago I noticed on a drive that the o/d selector switch doesn't turn the overdrive off. Somewhere around the same time I noticed that the easy entry for the memory seats doesn't work. I have reprogrammed the settings for the seat, but no change. If I hit 2 ( for me ) after my wife has been in the car, the seat and mirror will move to the correct position. I don't think that anything is actually broken with either problem, but I do think that I just need to "re-boot the computer". I unplugged the battery for a few hours, but it still remembered everything !! Should I overnight this ? Are there any fuses that I could remove that would accomplish the same thing ? Anything else I could look at ?
UPDATE: Seats are working again. Further exploring revealed a fuse for the o/d cancel switch. I checked it and it was fine. Mystery continues. Guess I am going to have to figure out how to get the switch out to check it. Either that or see if it might be covered under warranty somehow.
