Engine oil cooler
Platinum White
Has anyone added an engine oil cooler to their Edge?
I'm thinking about adding one using a sandwich plate between the oil filter and engine.
I recently had an oil analysis that indicated oxidation.
One of the primary contributors to oxidation is heat.
Are there any technical issues with the engine oil pressure or flow that would/could be a problem?
