Everything posted by nextime
I bought mine new in Oct 2010 and from that day till approx last month I was averaging 18MPG all around driving. Now since it is warming up I have jumped up to 24MPG one time but staying steady at 23MPG now all around driving. I have just under 5000 miles on it. I am guessing it will fluctuate for another month or so and then stabilize. 2011 Edge SE 2WD
Again we agree to disagree. I am assuming you have never personally used a K+N filter or any top end oiled filter for a long extended period of time? K+N cant post results just on the filter alone cause everybody drives differently, in a perfect world we would all drive the same. And nope I just installed a K+N filter, driving habits stayed the same. Actually a tuneup was done 3 years after the K+N install but the MPG stayed the same, my bad I did a break job right after that is what gave me the 2MPG gain I guess along with the car wash (sarcasm). Oh and yes there was a clean new filter in my Windstar when I replaced it, I actually still have it cause I use this between Cleanings if I ever have to drive it. Oh and in the Explorer my Wife never knew I changed the filter with a K+N, she probably still doesnt know or care it is in there. When I rarely drive it I do check the MPG when I fill it up. How do you explain a gain in MPG on a vehicle where the driver does not know any changes were done? The Explorer averages only a 1MPG gain and rarely hits 2MPG gain. Still a 1MPG gain does save gas in the long run. Oh and the Windstar was owned for 1 full year before the K+N was installed. The Explorer was owned appox 2 1/2 years before the K+N was installed and was delayed due to buying a new House and a Child Birth. My reasoning's is I never stick addons or unnecessary cash into a used vehicle till it has proved its worth for a year or so. I didnt even mod my 1992 Mustang or 2001 Corvette for over 1 year. So was the 2 MPG increase just in my imagination then even though after every fill up I check the math just to make sure nothing is wrong with my vehicle? And yes I do check the MPG after every single fill up just to make sure everything is working properly. I suppose you also think this is BS too even though it has a guarantee. They even state it gives a 1-3MPG increase. http://vararam.com/b2.html
Rearview mirrow w/ homelink, temperature etc.
nextime replied to sik-06's topic in Interior, A.C., Heat, Interior Trim
That is the exact number on the package you got? Just making sure cause I want one! -
No need to show it on K+N I have my own proof that I experienced, I also never stated K+N claims this but they do give a Gain in HP in the intake systems and all they are is smoothed out tubes that do not restrict air flow however some people say it is impossible to do this with mass air systems http://www.knfilters.com/cold_air_intakes.htm . If I did state this anywhere please direct me to the post. You can read FAQ #1 if you wish. http://www.knfilters.com/faq.htm#1
If you got it brand new what was the part number on the package? -
2011 Edge Sport rust spots on front doors
nextime replied to daconfusion's topic in Recalls, TSBs & Warranty
I wouldnt plug them up, Ford just doesnt add holes in the bottom of the doors for nothing..... They are drains. Every automobile door has these..... Everyone go look at other cars and see for your self! If there were no drain holes in doors do you know how heavy they would be after it rained and filled them up? All doors leak water internally, not alot but a little and they need to drain or at least breathe to exchange the moist air out. Now the Ford engineers designed the Edge with out door seals where you installed them for a reason to keep trapped water out and to let them drive out by air flowing over them during driving. I imagine this may void any rust warranties in this area now since you plugged up a drain hole and blocked out the natural engineered flow of water and air. I am guessing when the door was assembled some metal shavings got in there from reaming out a hole to attach some inner part of the door mechanism and that is where the rust comes from. If it was true in your case that you determined my Edge would have a rusted door too living up in Wisconsin where they coat the roads heavily with salt all winter long..... No rust in my doors!!!! I install GPS tracking systems part time (when jobs are available) and I have to drill holes in the roofs to add roof mounted antennas. When I do this if I do not clean up all the small metal shavings there is guaranteed to be small rust spots everywhere after the 1st rain. -
Squeaky driver seat
nextime replied to Calvin Krzebietke's topic in Interior, A.C., Heat, Interior Trim
Yes please post what was done? -
HMM my Edge 425 miles at 23 MPG is my average. Your math does not add up.... do you have a bigger fuel tank than stock? See if you look at my math 425 miles divided by 23MPG = 18.47 gallons of gas used Your math is 467 miles divided by 16.3MPG = 28 gallons of gas used..... Now I do not know of any Edge with a 28 gallon tank. You have to reset the settings right after and every time you fill up or you will get inaccurate readings. Sounds like there was 10 gallons of gas in your Edge when you bought it and then your Wife filled it up and never reset the settings!
Finger prints on Nav screen.
nextime replied to trainerdude's topic in Audio, Backup, Navigation & SYNC
Go to Radio Shack and get a LCD screen cleaning kit. It consists of a microfiber cloth and some liquid spray. I use it on all of my LCD screens (6 of them) and never had any issues. -
You will gain more MPG cause the K+N flows better all around. I know the mass air and blaa blaa blaa but explain why my 1998 Windstar and 1998 Explorer both gained approx 2 MPG with the K+N switch? Both have mass air and are fuel injected. Remember the engine is really an air pump, the more efficiently it can pump air the easier it is to spin. Now with a restrictive stock filter and a high flowing K+N the engine can breathe better with the K+N so the engine works not as hard via the stock filter. Now the only reason why I dont have a K+N yet in my Edge is cause I only have 4400 miles on it and the engine is still new. This summer when temps stabilize I will drop in a K+N and post the results. And If stock filters flow so much better and get the same MPG why do all aftermarket Turbo or Supercharger kits come with Oiled Filters? I know my Paxton was shipped with a K+N.
Grinding brakes is not normal. None of my cars do this except for when the pads are gone or if I let the car sit parked for extended periods of time and even after that a few taps of the breaks and it goes away!
Aftermarket Carpet Floor Mat Review
nextime replied to shiggins's topic in Interior, A.C., Heat, Interior Trim
I had Lloyds mats in my 2001 Corvette, I really loved them! -
Says who? You got proof that K+N filters do this?
On a few of my cars I have well over 100k with K+N filters installed, no engine problems and no burning oil. The oiled filter catches the bigger particles of airborne dust. The K+N filter Simply outflows stock filters. Now for getting engine oil dirty... My oil is as clean as it is with or with out a stock filter. I even went purposely and installed my stock filter back in for 1 oil change.... Oil looked just as dirty as with the K+N. I believe the postings of K+N filters letting big chunks of dirt through and all the other stuff is just rumors... Never saw a hard fact yet. You would think that the makers of stock type filters that do advertise on TV would go out of their way to let people know Oiled filters can damage engines if it was true just to sell their products!
Sounds like a tuner to me.
2011 SE Edge dash rebooting
nextime replied to sloowhand's topic in Interior, A.C., Heat, Interior Trim
Nope. I didnt even know there was one till I picked up my car. The dealer can tell you the TSB. -
There is a new TSB about the radio controls, this may address your issues. I just had the TSB done yesterday because my steering wheel radio controls did not always respond. I know when they did this upgrade when I got the car back my miles were in kilometers so I would guess the dash gauges may also get effected by this upgrade. -
Is that shipped price?
Mine is in service right now for the wind noise and this other TSB 11-03-07 Rear door popping noise. Original TSB for the pop was 10-14-1.
I am interested..... However I do not need Mirrors.... I would like headlights since everyone has headlights but not painted mirrors.
2011 Edge All Weather Floor Mats
nextime replied to rbuergel's topic in Interior, A.C., Heat, Interior Trim
Just cut a notch in the mat or use a zip tie to hold the wires up. You could even go far enough to remove the seat, cut the wires and extend them so you can reroute them..... This is what I would do to permanently fix the issue. The felt will eventually wear away and you would be back to square one. I guess I am just used to my Wife and I using the same seat settings. -
Sounds good.
