cal3thousand
Everything posted by cal3thousand
How to detail the interior
cal3thousand replied to ladybell's topic in Interior, A.C., Heat, Interior Trim
Clipped this little tidbit to Evernote. I'm sure I'll need it in the future with a 3 YO milk drinker and I'll forget the name by then... -
I'm going with your idea of the mobile tent with the screens on magnets and a cut out memory foam topper. Going to add the trailer for all the luggage and toys. Who needs a trailer large enough to sleep in?
Tire Cupping on insides of all tires.
cal3thousand replied to LAJAMA's topic in Brakes, Chassis & Suspension
Are you putting any heavy loads or towing? -
That's why you shouldn't be using shampoo. Shampoo is really a bunch of surfactants that help release the odor so it can be vacuumed up. And that may "resurrect" them as you put. That's where the Vinegar and Alcohol come in to chemically react and neutralize the odor chemicals. Here's a blurb I just found about Vinegar (it also contains information I did not know about Baking Soda): How do baking soda and vinegar remove odors? Actually, they neutralize odors rather than just covering them up. The secret is in their pH which causes a chemical change in the odorous compound. This chemical change might also help reduce the chemical bond of the compound to the fabric. Most odors come from compounds that are either acidic or alkaline / base. “Alkaline” and “base” are just different names for the same thing. It is necessary to understand pH to fully understand how baking soda and vinegar neutralize odors. What really is pH? Let’s get chemical for a moment. The term “pH” is an abbreviation of “potential hydrogen” and refers to the amount of hydrogen ions present in a solution. A hydrogen ion is a hydrogen atom that has either lost an electron (H-) or gained an extra electron (H+). So, pH is a measure of the concentration of hydrogen ions in a solution and varies from 1 (highly acidic) to 14 (highly alkaline or base). Pure water is neutral with a pH of 7. Vinegar is acidic with a pH of 3 and baking soda is slightly alkaline with a pH of 9. Washing soda has a pH of 11. Vinegar and baking soda help to balance pH levels by changing the chemical structure of odor-causing acids and alkalines bringing them closer to neutral. Because it is acidic, vinegar is more effective at neutralizing bases, and baking soda is more effective at neutralizing acids. If you mix vinegar and baking soda together when soaking smelly clothing, they will mostly cancel out each other. -
Using a steamer like Dingo suggested would help. In my experience, to remove really stubborn chemical induced smells you need something that works at the molecular level. Vinegar has the ability to neutralize many odors. I would mix it 20/80 with water. OR 10% Vinegar / 40 % Alcohol / 50% water and use that as carpet cleaner solution. It will stink like Vinegar until it dries and airs out. The alcohol will assist with that. Once the vinegar smell is gone, so should the smoke smell. EDIT: I should include that I would only suggest this on cloth seats and carpet. NOT leather. -
Thanks for that tidbit about warranties. Didn't know that.
Weak AC fan blower - how to clean filter
cal3thousand replied to scotthan's topic in Interior, A.C., Heat, Interior Trim
Right? ldybell was able to post, go out and change the filter and repost in 12 minutes. $75? .. that's economics at its finest -
From what I've seen (during tire rotation), the metal is just unfinished aluminum. It's probably machined lightly. I wouldn't expect anything "finished" as that would be prohibitively costly.
The memory foam sounds like a great idea. Costco sells the mattress toppers that could easily be cut. I'm liking the "mobile tent" option... going to have to get a small trailer for all the luggage and goodies so I can camp out in the car!
I ask because my experience with getting it to read messages recently included an advanced menu. But I'm on a custom ROM with Android 2.3.4 as the base. I had to allow messaging access (for sending sms) and the FTP service (for reading sms)
I've napped in the back, but that's about it. It's not bad as long as you have padding and a blanket. Can't imagine it would be anything but rough otherwise. I like the idea of the car tents, but only in moderate weather.
That's what it is.
I like the 3rd option. I've always like the meshies!
Question Regarding TSB AS-21769 or TSB-11-5-6 Ford Engineers?
cal3thousand replied to blankster's topic in 2011 Edge & MKX
Edge has this feature (fuel cut on hill descent) and also Smart charging which allows the Alternator to put an increased load on the drivetrain during deceleration to maximize efficiency. -
Go into BT settings in your phone and see if there is an advanced menu.
Ask A Professional Detailer?
cal3thousand replied to CanuckG35's topic in Appearance - Detailing, Wash & Wax
Same thing here. But I thought it was my fault for trying this Rain-X anti-fog crap. It was like buttering my windows to stop condensation . Since then, I've been unable to completely eliminate it. It magically reappears in a week. O_o -
Sorry to bring this thread back from a state of coma, but I just found a drink that smells like ONR: Monster M-80 is a juice blended energy drink with Apple, Passion Fruit, and Pineapple Juice concentrates listed as the first few ingredients Put it to my lips today and almost put it down because it smelled so much like my weekend carwashings.
Samsung Phone Compatibility
cal3thousand replied to EdgeMan51's topic in Audio, Backup, Navigation & SYNC
Do all the SMS features work for you? -
LED's in side mirror puddle lamps
cal3thousand replied to Diesel350's topic in Accessories & Modifications
That guy deserves a beer! -
Yeah... I thought no update since I was on 2.11. But low and behold, Syncmyride.com offered it up. O_o And you're right, it was a half-ass job! Because the services screen was all jacked from it. I'm not certain what exactly triggered the magic of SMS. Solution could have been 2 fold. And while we're on the subject, I finally got it to READ me a text!!!! In Android you have to enable 'FTP service' in the BT Advanced settings for reading new messages. (BTW, this is a relatively new phone (MT4G Slide) so I'll have to bust out the older phone (MT4G) and see if I can replicate. As for the TPMS, it was actually right! The right rear tire was low about 8psi versus the others. I'll have to keep an eye on it in the event I have a bum rim/tire.
