johnmarkp
Everything posted by johnmarkp
I just ordered 4 Pirelli Scorpion AS PLUS 3 tires from Tirerack. I hope to get them installed soon. I'll report back on how they perform.
The more I think about it. The clicking sound when I jacked up the wheel is probably normal when the car is in park. I think I have heard it before. The clunk when slowing down is slowly getting worse. Time to a drive to the dealer. Luckily it is still under the Ford extended warranty.
They look good, but the 20k mileage is just too low.
With on side of the car jacked up I get a clicking sound when I move the front wheel back and forth in the direction of rotation. It is the same for both wheels. (the other front wheel is on the ground). Is this normal? I can't remember if it made this sound in the past.
I have looked at virtually all the tire reviews for the ST. Most are centered on performance and/or mileage. I am looking for tires that give the quietest and most comfortable ride. I have the 20 inch wheels.
I just started getting a clunk sound when I take my foot off the gas. I also get it when I am slowing to a stop at a couple of miles per hour. I will put it up on stands tomorrow and check the CV joints and anything else I can wiggle on the front end. Has anyone has a similar thing happen?
I had the it mixed up with another car remote. I would not be too worried about the electrical components. They are probably all surface mount components. The only risk is shorting out the contact legs with crap from the detergent. The big risk is to the switches. They are most likely film contact switches. Crud could get trapped in between the plastic cover and the membrane and prevent the switches from working mechanically. I would leave it in distilled or RO water for a couple of minutes and press all the buttons many times while under water to get all the detergent out. I am a bit OCD so I would probably do this three or four times. Then soak in alcohol a couple of times and let it dry for a couple of hours. I would not wait to do this because any left over detergent will be harder to get out with more time.
The case can be taken apart. Just look for the directions for replacing the battery in the key fob.
You can get the connector and or a repair pigtail from Ford at a very steep price. That connector and the connection pins are commercially available. The problem is figuring out who made the connector. I start out by getting the Ford part number from the wiring diagram and searching for that number. Often an ad will tell you the part number for the manufacturer of the connector. A lot of them are made by Molex. The listing on for connector on sites like Digikey will tell you the connection pins that fit into the connector.
Adding Adaptive suspension to my ST
johnmarkp replied to johnmarkp's topic in Brakes, Chassis & Suspension
Does anyone have any idea how to do the initialize to vehicle thing? Or any other work around for that matter. I am stuck on this project. -
Thanks. Lots of differences. I will have plenty to do on rainy days.😊 -
I did not get it to show up. I confirmed that it was powered up and I am 99% sure that the CAN2 was hooked up properly as well. I assume that the profile characteristics are in as built database. I cannot figure out how to fool the system. It would be interesting to compare my 2019 ST with a 2019 Nautilus with and without Adaptive suspension. Can we still get the as built data by VIN number? I don't remember how to view the as built data, can someone remind me? -
Retrofit 360 Camera Into Ford Edge
johnmarkp replied to Wubster100's topic in Accessories & Modifications
I wonder if you could make these with some 3D printing and creative cutting. I am pretty sure there is a enough room in the mirror case for the camera. -
I did create the new profile. I am going to try a different place to grab the CAN2 signal and make sure the signal is actually getting into the VDM -
I got the VDM and the connectors. I ran power and CAN2 (from the headlight control module) to the unit. The car does not see the VDM according to forescan. The VDM is powered up, I got 5v on the height sensor reference voltage pin. I reversed the CAN2 wires just to make sure. The wiring diagrams have the + and - switched sometimes. I put a cheap scope on the CAN2 wires and it looks like I have the right ones. I think there may be a setting in a module somewhere that tells the car that VDM is part of the allowed configuration. I tried changing the setting in the IPC that turns on the display part and it would not write. It gave a module configuration error. Not sure what to do next. I only found one reference to "Continuously Variable Suspension" on all the usual forescan type sites. It is for the IPC part. -
I decided to buy the official Ford Wiring book. Got a good deal on fleabay. Well, leave it up to Ford to screw it up. The books cover says "2019 Edge". In reality it is for the previous generation Edge, 2018 model year. There is no actual mention of the years covered. But the drawings of the Edge are for the 2018 generation vehicle. I just have to scratch my head on this one.
- 1 reply
- 2
Thanks. I wonder where C1026 is? Looks like an empty connector. -
I looked at the HCM yesterday. It does not match the wiring diagram that is in your thread on the 360 camera. I see references to the Gateway module, but I cannot find any documentation for it, including the location. What am I missing? -
I have the VDM and one height sensor on order. I got a the height sensor because I want to confirm how it communicates the back to the VDM. I thought it was a simple voltage divider, but after looking at the service manual again, I think it might be a Hall sensor. I'll know for sure soon. -
I think I am going to buy the control module to play with. I am trying to figure out how to tap into the CAN2 line. Anyone have any suggestions? -
My first idea was to only make the shock rates adjustable without being adaptive while driving. The cost and the risk of the system not being recognized by the Edge being the main reason behind my thinking. I might just buy the control module above and see if the car will find it. Then I could play around with Forscan and see if I could get it to work. I would use simple fixed resistors for the ride height and shocks. The service manual gives the proper ranges for the resistance. I have not given up. -
The Lincoln mirrors are attached to the sheet metal not the small triangle by the glass. The sheet metal profile would have to be close. Not to mention the replacement part for the plastic Edge mount. Too bad, it would have made things pretty easy., -
Looking Beyond Edge being discontinued
johnmarkp replied to enigma-2's topic in Buying, Leasing & Ordering
I am not sure that the Hydrogen is any more dangerous then having 10 to 20 gallons of highly flammable gasoline on board. -
This is on my spring to do list. HAZ, do you have access to the wiring diagram that will give me the part number for the female connector? Is is C4044, left rear damper solenoid. Thanks -
Hood insulation and Engine cover noise reduction
johnmarkp replied to fishx65's topic in 2.0L EcoBoost
We added the hood blanket and engine cover to our 2019 SEL. It made a noticeable, but not dramatic decrease in sound. The 2 liter is pretty noisy. Not the engine itself, but the air intake design is bad and causes a lot of high pitch noise. Ford says it is not a defect. Knowing what I know now, I would still add the two parts if I bought an Edge without them.
