johnmarkp
Everything posted by johnmarkp
Retrofit 360 Camera Into Ford Edge
johnmarkp replied to Wubster100's topic in Accessories & Modifications
I wonder if you could make these with some 3D printing and creative cutting. I am pretty sure there is a enough room in the mirror case for the camera. -
Adding Adaptive suspension to my ST
johnmarkp replied to johnmarkp's topic in Brakes, Chassis & Suspension
I did create the new profile. I am going to try a different place to grab the CAN2 signal and make sure the signal is actually getting into the VDM -
I got the VDM and the connectors. I ran power and CAN2 (from the headlight control module) to the unit. The car does not see the VDM according to forescan. The VDM is powered up, I got 5v on the height sensor reference voltage pin. I reversed the CAN2 wires just to make sure. The wiring diagrams have the + and - switched sometimes. I put a cheap scope on the CAN2 wires and it looks like I have the right ones. I think there may be a setting in a module somewhere that tells the car that VDM is part of the allowed configuration. I tried changing the setting in the IPC that turns on the display part and it would not write. It gave a module configuration error. Not sure what to do next. I only found one reference to "Continuously Variable Suspension" on all the usual forescan type sites. It is for the IPC part. -
I decided to buy the official Ford Wiring book. Got a good deal on fleabay. Well, leave it up to Ford to screw it up. The books cover says "2019 Edge". In reality it is for the previous generation Edge, 2018 model year. There is no actual mention of the years covered. But the drawings of the Edge are for the 2018 generation vehicle. I just have to scratch my head on this one.
- 1 reply
- 2
Thanks. I wonder where C1026 is? Looks like an empty connector. -
I looked at the HCM yesterday. It does not match the wiring diagram that is in your thread on the 360 camera. I see references to the Gateway module, but I cannot find any documentation for it, including the location. What am I missing? -
I have the VDM and one height sensor on order. I got a the height sensor because I want to confirm how it communicates the back to the VDM. I thought it was a simple voltage divider, but after looking at the service manual again, I think it might be a Hall sensor. I'll know for sure soon. -
I think I am going to buy the control module to play with. I am trying to figure out how to tap into the CAN2 line. Anyone have any suggestions? -
My first idea was to only make the shock rates adjustable without being adaptive while driving. The cost and the risk of the system not being recognized by the Edge being the main reason behind my thinking. I might just buy the control module above and see if the car will find it. Then I could play around with Forscan and see if I could get it to work. I would use simple fixed resistors for the ride height and shocks. The service manual gives the proper ranges for the resistance. I have not given up. -
The Lincoln mirrors are attached to the sheet metal not the small triangle by the glass. The sheet metal profile would have to be close. Not to mention the replacement part for the plastic Edge mount. Too bad, it would have made things pretty easy., -
Looking Beyond Edge being discontinued
johnmarkp replied to enigma-2's topic in Buying, Leasing & Ordering
I am not sure that the Hydrogen is any more dangerous then having 10 to 20 gallons of highly flammable gasoline on board. -
This is on my spring to do list. HAZ, do you have access to the wiring diagram that will give me the part number for the female connector? Is is C4044, left rear damper solenoid. Thanks -
Hood insulation and Engine cover noise reduction
johnmarkp replied to fishx65's topic in 2.0L EcoBoost
We added the hood blanket and engine cover to our 2019 SEL. It made a noticeable, but not dramatic decrease in sound. The 2 liter is pretty noisy. Not the engine itself, but the air intake design is bad and causes a lot of high pitch noise. Ford says it is not a defect. Knowing what I know now, I would still add the two parts if I bought an Edge without them. -
Any update on this. I may want to do the same thing this summer on my ST. In the Beefnuts video, what is the red brace in the cargo area? -
So far so good. I cleared the DTC an it has not come back.
- 1 reply
Got the check engine light. Found the P0461-00:AC from the PCM P0461-C from OBDII. The Status says, DTC maturing-intermittent at time of request. I will clear the codes and see what happens. Hopefully it is a glitch in the system, not a problem in the making.
- 1 reply
I gave up on the Ford parts, both original and updated. I use TOGGLER TC wall anchors. I cut off enough of the vertical fins, that help grab drywall, to allow the toggle to go through a 3/8 inch fender washer. I hot glued 1" OD x 1/2" tall x 1/2" ID nylon spacers (McMaster #94639A876) to the inside of the covers. I inserted the toggler where the old Ford part was and then used the toggler tool to set the toggle. I did this two years ago and all are sill holding strong.
- 91 replies
- 3
- dash noise
- dash rattle
(and 4 more)
I am pretty sure I got the Advanced Auto version of these. I ended up having to shave a milometer of plastic off the ends of the two engagement thingies. (not sure what they called) YMMV
Problem with camera heating
johnmarkp replied to Iroga's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
That makes sense. I guess you need a bigger freezer. 😀 -
Maybe you could try holding some ice cubes over the camera area of the windshield. Or just block it with a post it note. I am not sure what causes the heater to be activated, but blocking the camera is a good start. John -
Did you have to do anything in Forscan, or did this work just by plugging it in? -
I don't think this is available on my 2019 ST. I wonder if it could be turned on with Forscan?
2024 Edge rattle noise from rear cargo trim panel
johnmarkp replied to lasseventies's topic in 2.0L EcoBoost
There is a slight chance that the rear license plate is loose. I had a rattler that only happened at higher speeds. I did not figure it out until the plate almost fell off. The Ford capture nuts are not very good. It is easy to over tighten and break them.- 29 replies
- 2
2018 - 2019 Edge Key Fob programming
johnmarkp replied to tk2fast's topic in Alarms, Keyless Entry, Locks & Remote Start
I can confirm a couple of things with regard to getting a new key, if you only have one key. The dealer van just left and the new remote is working perfectly. The cheap ebay remotes work fine. At least for my 2019. https://www.ebay.com/itm/383672810625 They are not Ford parts, but very good knockoffs. As dabansta says above. A used remote can be reprogrammed. Total cost $123 for the key and programming. Much better then the $300+ the dealer wants. -
Does the third key have to be new, or can a used key be used. In my case the used key would be from an edge of the same year.
