KonaBlueSport
Everything posted by KonaBlueSport
I have a 2001 Edge Sport. I don't want to run the 22's in the winter with the heavy salting that's done in my area. So I purchased a set of 18 in Edge wheels from eBay. The issue is that they do not come with tpms sensors. I'm not sure if the 2011 Edge comes with in valve stem sensors or the strap on bands. Which one is compatable with my Edge???
Saw these on a person's car in Detroit
KonaBlueSport replied to livingontheedge16's topic in Accessories & Modifications
If you look at all of the OPs posts they all link to the steeda site. Mighty suspicious if you ask me. -
Rear Differential fluid change procedure
KonaBlueSport replied to evh's topic in All Wheel Drive (AWD)
Nice writeup. I'm sure it will help out all the do it yourselfers. -
Cannon instead of posting a cryptic reply why not give us the full story......... That way if there is really a issue we can make a informed conclusion on if to buy or not to buy.....
Sounds like a done deal then. Please pm me to get this done.
what color is your EDGE??
Cost of shipping to 20902?? Ready to buy pending shipping cost...
Billett
FYI the sd cards are not vin specific. My Sport was missing the sd card on delivery and the salesman walked over to another Edge and took it's sd card and installed it in mine. Worked normally with 0 issues.
Jonny you have a maint minder system that will tell you when to do your oil change. It can be as high as 10,000 miles between changes. This being said if you havent reached that mileage than 1x a year as a minimum is advised. I personally don't feel comfortable with such a extended service schedule so I will do mine in 5,000 mile/6 month intervals which ever comes first....
Generally when you get a wheel that has a center cap covering the lug nuts the nuts are of the exposed variety. Usually this is because the closed ended ones are longer and will not permit the center cap to mount properly. That said the center cap is good at protecting against elements and generally will not have a issue. If your concerned about rust causing the lugnuts to sieze on the lugs you can put a bit of antisieze compound on the lugs...
I have a 2011 Edge Sport as well. Bit the bullet and ordered the rear bumper protector from streetsideauto.com.. It arrived today and is almost a perfect fit. Install took all of 3 minutes and it should protect the rear bumper for years to come. Order one for a 2010 Scion xB but before placing your order google for coupons as there is a $5 off coupon available. Well worth the money....
2011 Ford Edge Sport - Ticking sound after i start it
KonaBlueSport replied to Jonny Zero's topic in Lounge
Have the same issue. My Edge Sport is 2 weeks old and has less than 1000 miles. It's at dealer for some owed paint repair and I told my service advisor about the noise. He says there is a ten on the injectors that can be causing the noise. My thought is it's the cold start injector... -
1 month so far with my Kona Blue Sport and I love it...Traded in a MazdaSpeed6 for it and dont regret it 1 bit...
Awsome color...Its the 2nd bestest color for a Edge with Kona Blue being the bestest ever.......
Looks nice... Love the color ~
Front License plate holder REMOVAL
KonaBlueSport replied to Edgieguy's topic in Accessories & Modifications
www.bumperplugs.com might be the way to go.... -
Venza made in the USA Edge made in Canada....
As others have stated are you sure the new battery is charged?? Being new doesnt guarantee its at a full charge. It may be defective from the factory or sat for a while and be low on charge. Did you try to jump the car b4 buying new battery? If so mioght it have been jumped backwards? Check fuses/fusable links/relays to see if the main fuse/relay is burned out...
Hmmmm. Might work as a winter wheel set.
2011 Kona Blue Edge Sport owner checking in
KonaBlueSport replied to KonaBlueSport's topic in Welcome Forum!
Joe-Pics will be up shortly..... Edgieguy- I sold one just driving to my dealer to turn in paperwork... Lady followed me from the highway n asked if I got my Edge there. I said yes and she replied that she wanted one. Got her over to my salesman n they were negotiatin price when I left.... -
Dragster if your doing a proper "-" sizing on your tires when you do down from the 22in wheel to the 18' wheel your speedometer should not be off enough to be noticeable...
Just picked up my 2011 Kona Blue Edge Sport Thursday nite. Love it so far and its a real head turner....Checking in n saying hi....
