11Edge
Everything posted by 11Edge
I had not even heard of MFT when we started looking at the Edge. We have had ours 13 months now with zero problems. MFT has been annoying a couple of times but nothing that I would down rate the car over. Because the car hasn't been driven much, and mostly in town, I took the car to the shop that I have been doing business with for several years to have the oil and filter changes at about 3,000 miles. Early, I know. Last month I took it to the Ford dealer where we purchased it because they had a special on where I could get more than the oil and filter changed for $30.00. Had the tires rotated for no additional cost. That is the only time the car has been back to the dealer since we bought it. This time the car had a little over 5,000 miles. Overkill on the service. Will be going back at 5,000 mile intervals from now on.
The cabin air filter is on the firewall behind the glove box. Opening the glove box allows more air flow. There are threads on this forum about dirty cabin air filters blocking the airflow so that the A/C wouldnt work right.
Everytime my wife asks me what the temp is. And with trifocals and sunglasses (clipons) it takes a while to focus on the itty bitty display. Dangerous!
On appeal a judge overturned the Honda lawsuit. http://reviews.cnet.com/8301-13746_7-57431148-48/the-honda-hybrid-lawsuit-saga-ends/
2011 Edge SEL adding factory back up cam
11Edge replied to 20Edge11's topic in Accessories & Modifications
Must be a Canadian thing. Our SEL came with the backup camera. -
Front parking warning like on the back. My 2004 Merc Monterrey has them on the front and I sure do miss them when I'm parking the Edge. It looks like I'm about to hit the wall and there is still four feet of clearance. DRL's. Adjustible (front to back) headrests.
My 1990 Sable did the same thing. I learned how to drive so it wouldn't do it. Kept it until 2004 and traded it in on a 2004 Mercury minivan. Having said that, it appears that the problem won't be "fixed" by changing driving habits. I will keep the seat of my pants alert in case if happens to me so I can demonstrate it to Ford if needs be.
Yes, having the parking brake set will get a false positive It has happened to me.
I was suprised at the outcom of the case. Isn't there a disclaimer on all window stickers that basically say that your mileage may vary? Options, driving habits and condition of vehicle all effect fuel economy. Terrain also plays a part. My brother lives near the gulf coast in south Texas. He gets the same fuel economy in his old heavy Chevy Caprice as he does in his minivan when on the highway because there aren't any hills to climb.
Major Upgrade (Rewrite) Details
11Edge replied to netizenX's topic in Audio, Backup, Navigation & SYNC
Me. I have had little or no problems. An occasional hiccup but that is all. -
Mine didn't either.
Weak AC fan blower - how to clean filter
11Edge replied to scotthan's topic in Interior, A.C., Heat, Interior Trim
[2. Remove the clip on the right side that is attached to the "string" that "hinges" the glove box.] My clip is on the left side. Does the clip slide down? There doesn't seem to be enough slack in the string to move the clip down far enough. -
Installing rear view camera
11Edge replied to edgemaster's topic in Audio, Backup, Navigation & SYNC
I do. 2011 SEL. -
The lens is near the release button in the liftgate. Oops. By bad. The lens is above the license plate. With the motor running and the transmission in reverse look at the left 4 inch screen. See if there is a notice saying that the back up is off. If it does show up scroll with the left buttons to the "on" dot and press OK. Hope this helps.
Sync my ride MFT upgrade avaliable?
11Edge replied to mv-clear's topic in Audio, Backup, Navigation & SYNC
My update was stuck on 6 of 9 for a long time. However, the light on the thumb drive was flashing for most of this time, so I guessed that it was a big file. When the light quit flashing I got a little worried, but it eventually finished all 9 files. About 45 minutes for me. -
I had a 2000 Impala that had water in the passenger side. Had to take in in three times before they got it fixed permanently. In my case debris was falling into the condensate drain hole an plugging it up. It was enough of a problem that GM issued a TSB. I don't think that this is your problem, but it is at lease worth asking about.
If done right I don't think you need to worry about paint fade. I live in the Dallas-Fort Worth area. Our 2004 van was side swiped January 26, 2004, the first month that we owned it. The paint on that side is fine. The other side was sideswiped a couple of years after that and it also looks show room new. Have the work done where they give a guarantee for as long as you own the car. It may cost more but it is worth it. Red seems to attract bad drivers.
Got a reply from Ford the same day I posted my situation. They said that their data base shows V2.11 loaded on my car and to disregard the comfirmation error. -
I have reported the successful install several times but I cannot get confirmation. Some of the files are confirmed install on the Snycmyride but some are not. I downloaded the status checker but when I put the thumbdrive in the car, the screen never indicated that and install was in progress although the light on the drive would flash slowley. I have sent an email to Ford about my problem. I emailed them before with a question and they were quick to respond. Glad to know that you can drive during the update. Idling for 45 minutes knocks heck out of the MPG. The touchscreen does seem to be more responsive now. -
Have you asked this question on the forum for rvers? www.rv.net They have a section on dingy towing.
Our first phone was a big wooden thing mounted on the wall with two big batteries supplying the power. You took the ear piece off of the hook and turned the crank. If you were calling on your party line you would crank like two longs and a short or whater ever. No matter what you cranked, the operater would come on and ask for the NAME of the person you were calling. In 1953 we moved to another state and did not get another phone until about 1957. You would dial the first two letters of a name. All of the phones in our town were on the same name so we only had to dial 5 numbers. We got our first TV in 1953. No changing channels because there was only one. It came on at 2:30 in the afternoon and went off at midnight. Eventually we got cable and could get four or five channels. No VCRs to record for later viewing.
Yesterday afternoon just after 4 pm I was behind a pickup truck that had tinted tail lights. I could barely see his brake lignts or turn signals. A potentially dangerous situation.
Keyless Entry Keypad System - Purpose?
11Edge replied to jdf77's topic in Alarms, Keyless Entry, Locks & Remote Start
I sometimes use the feature simply because its there. :D -
Brake fluid is hydroscopic. It absorbs water. The water in the system gets hot and "boils" and turns to steam=gas. The gas then compresses when you apply the brakes.
We got our SEL on April 28, 2011 and have had triple digit heat nearly every day. No problem with the a/c cooling down quickley, even before we got a windshield for the car.
