vega
Everything posted by vega
I have a v6 2015 Edge SE. At the rear bottom, next to, and slightly above, the driver side exhaust tip, there's a female 12pin oval looking connector. Is this for trailer wiring? If so, what kind of a connector is needed for a trailer? Sorry if this isn't the correct forum but I could'nt pin it down to which it belonged to. Thanks
I placed sound mats in the spare tire area and removed the wheel well skirts and coated the interior side with underlayment rubber spray. Improved greatly. However, I find its the type of tires and size to be the main culprit. IMO
Yes, same with my gen2 2015 awd. Thought it was just me cause I stand only 5'5" tall. Also, I noticed on long trip that the gas pedal pressing force is harder than a gen 1 edge. Not by much, but enough that one notices.
Taillight socket melted
vega replied to edgemaster's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
I had two Audi's that did the same thing and was told to apply silicone grease to the base interior and bulb base by the dealer. It worked. Now I always use it for all bulb contacts and connectors. -
3rd Brake light 2015 Edge question
vega replied to vega's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Well, since we are now reduced to speculation and conjecture about accident causes, I'd venture to say that the number one cause of rear end accidents is tail gating, I will never understand why the fool tailgating me thinks that by doing so, traffic will travel faster. -
I plasti dipped my grill and it looks great. By mistake, I applied Trimshine on it and it's now shiny and sealed! Nice mistake.
Yes, I did it exactly the way you said. Thanks for the input regardless. Mine also disables for stop and go traffic. -
It's scary to think that they give a drivers license to people who can't even ride a bike. -
Mine drive great at any speed.
Yes I understand the law and federal preemption but a state trooper cannot write you a federal violation ticket, only one based on state statute. I will risk the ticket. Pretty stupid antiquated federal DOT laws out there. Always twenty years behind. I just can't wait. -
The federal law is a safety standard by which all manufacturers must follow while State law governs lighting you display on your vehicle while in use. For me, Illinois prohibits all flashing lights with various exceptions for emergency vehicles. The statute prohibits flashing which in turn is defined as continuous. Three flash then steady brake light is not continuous. It can be easily be replicated by pumping your brakes. Don't know about other states. -
That may be true but I see them all the time. On a Kia, it's standard equipment from the factory. As to being annoying, that's the point. Too many drivers are asleep out there. I have three cars and have a flasher on each. I'm tired of getting rear ended at stops with the obligatory, "Oh sorry, I didn't see you." -
Key Fobs from other Ford cars
vega replied to Edgieguy's topic in Alarms, Keyless Entry, Locks & Remote Start
I don't think so. Open your fob and look for a ID number. Then google that number, or even ebay the number and you'll find the correct one. -
Well, I gave up on removing the third brake light. I wanted to put in a flashing module. I found that the trim from underneath popped right out. From there, I found the harness connection to the light and spliced in a connector which in turn hooked into the module. Oh, by the way, because of Ford's modulated type of current, the only module I got to work was Signal Dynamics Backoff. type 1001 (which is the original). Now the third brake light quickly flashes 5 times and then steady on when the brakes are applied. -
Did you program them according to your manual/?
Just to be clear, if you order from ebay, also applies to all refurbished fobs, open your key fob down to the battery and write down the number you see. You want the EXACT number on your new one in order to avoid fobs that look right but will not program. I just went through this mess and it wasn't pretty. Good luck guy.
Hood pin location in 2017 ford edge
vega replied to NoisverWen's topic in Alarms, Keyless Entry, Locks & Remote Start
I have a 2015 se model and have a hoodswitch. I have no remote anything or alarm. If my hood is not latched I get a warning on my display. My point being it may be year specific. -
vega replied to ben senise's topic in Accessories & Modifications
For me, knowing little to nothing, this really helped: http://www.2gfusions.net/showthread.php?tid=4573 -
Thanks for the reply. I guess three fob will do for now.
Open your hood and start the car. If it says your hood is open or ajar, you have the pin and you don't need to do anything further. The remote start just needs to have one present in order to work correctly. (I think all our Edge's have one. At least 2015 forward) As to the remote install, I did mine myself. The hardest thing was removing the cowling under the steering column and disconnecting and reconnecting the pigtail connectors. Need small hands and lots of patience. Although not for the Ford OEM remote start, this video was for mine and was instructive. https://www.youtube.com/watch?v=fB3j7hCHYLg -
I have a 2015 edge se. Just bought 2 extra keys to program. Programmed the first one no problem but...when I tried the second it said maximum keys programmed. I see that the car says it has 4 admin keys programmed. I only got 2 fobs when I bought the Edge. That means there is an admin key out there in the wild. (programmed before I purchased the car) At least I now have 3 keys. Is there any way to wipe out all extra keys so there are only 2 admin keys so I can program the other two????
