About TNEdgeOwner
TNEdgeOwner's Achievements
Leave key fob in car?
TNEdgeOwner replied to Donny Star's topic in Alarms, Keyless Entry, Locks & Remote Start
Hmmmm, I have a 13 SE and I lock my key inside all the time and use keypad to get back in........no 7-8 9-0 buttons, no nothing......just lock and walk! ?? Just noticed OP's car is Limited, mine probably works because I don't have pushbutton start?? -
Heater core or H2o Pump?
TNEdgeOwner replied to Father of Ford 702's topic in Interior, A.C., Heat, Interior Trim
If you are noticing a smell that is coming from your air vents, that points to heater core. Anything going wrong with the WP would not be doing that. -
What coolant - Gold or Green
TNEdgeOwner replied to chotabeam's topic in Interior, A.C., Heat, Interior Trim
You should use the search function on here and read a bunch. The coolant topic has been discussed a tremendous amount already. Cheers! -
Lol......that's old dried chocolate shake that the previous owner musta spilled! I cleaned all that up.......Yuk! ?
I recently re-did the stereo/sync arrangement in my 13 SE and while inside the console saw a small round device of some kind that faces forward into the small storage cubby hole that is under the front of the console. I tried looking up the "part" numbers that are on the device and on a tag that is fastened to the wire leading to the device, with no luck. Is this a small accent light that is burned out perhaps?? Ok sleuths, what do you say?? ?
Dried blood on headliner
TNEdgeOwner replied to bubbadewsky's topic in Interior, A.C., Heat, Interior Trim
Blood stains, even old dried ones can be cleaned with hydrogen peroxide. Soak - blot, soak - blot, over and over until gone. No rubbing. -
Backup camera wiring ?.
TNEdgeOwner replied to Mike Westerman's topic in Audio, Backup, Navigation & SYNC
Am giving this post a bump please.............I too am wondering where under the dash or at the inside fuse box is a reverse signal??? 2013 SE...........Thanks ? -
Transmission Flush, or simple drain and fill?
TNEdgeOwner replied to slides's topic in All Wheel Drive (AWD)
You are buying correct Motorcraft fluid, correct??- 105 replies
- transmission drain and fill
- transmission flush
- (and 2 more)
TNEdgeOwner changed their profile photo
Cooling Fans Won't Turn On, MKX Overheated, schematics needed
TNEdgeOwner replied to jeffr_vws's topic in 3.5L
2013 SE 3.5 58,000 miles Been reading for hours and am running out of ideas......same problem, fans will not run with a/c on. Done so far: ordered a new motorcraft fan assembly from rockauto > installed and still no fans > fuse (60A w/o tow pkg) good > 12 volts to FCM good > each fan (old & new) run with 12 volts applied. The small white and blue control wire at the main plug in to the FCM is not receiving the signal from the PCM telling the fans to come on. Had the battery out yesterday for a couple hours and when I hooked it back up ....Shazam!! the fans came on!!......for about 2 or 3 minutes, then right back to no good Am showing 2 trouble codes in Forscan, I can clear P0480 and it will come back after trying a/c again, can't clear P160A and in my reading am assuming it is there because of a few changes I did with Forscan like pk lamps as DRL's, disable bulb out check (for running LED's) etc. So to wrap up, there are no temp or pressure sensors that could be the culprit and I am probably going to have to go to the dealer to have my PCM checked out. Anyone have anything else for advice??....and thanks!! -
Ok, so I knew when I bought my 13 SE that the stereo would be tricky to live with and just yanking out the factory unit and sticking in an aftermarket stereo would not be simple or cheap. I would like to ask a couple of things......can someone confirm that I have Sync v1.5 in my Edge by the pics?.....and second, I have tried everything I can think of to get it to auto start/play bluetooth media stream when starting the car but I can not ? it starts on "SYNC Line In" every time even though I changed it to bluetooth in the settings (I think). I have a spare phone (OnePlus 3) paired as primary phone and am streaming Spotify, but every time I start up I have to go thru the media menu and select bluetooth for source. Oh, and one more......I have forscan loaded on my laptop and am all set to start experimenting, is there any control of sync available in forscan??? Thanks!!
Thanks!!
Hello, new here and new (to me) '13 SE owner. Right in the middle of the engine bay just behind the grill is a 2 wire plug that is just "parked" onto a plastic matching plug mounted to the front structure. I'm assuming it's for an option my Edge doesn't have, can someone tell me what it is ??? Thanks
Well....new to me anyway!! ? Hello everyone, just bought a 2013 SE bright silver with 56,650 miles clean as a whistle. Have already learned a bunch from this forum and now am official member. Cheers ya'll!!
