  • 1 year later...
There is more to this than wiring. And NO there are no wires other than what you had at factory. There is at least one full row pins present on the mirror itself but if you look at the harness plug in the car its only populated with the features installed. I don't know what the inside of the mirror connector looks like but I was inside the mirror on my Edge yesterday and there were only wires for the power motor, nothing else.
If you have memory, bliss, power mirror,heat and an MKX with dimming mirror you will have a nearly full harness of 13 out of 16 wires populated.
