Replace License Plate Bracket - new grille inserts?
candurin
Quick question, I finally decided to bite the bullet and I picket up the primed grill inserts. I don't plan on painting them, as they will match the matte color of my PD'ed rims.
I am going to keep my old set as backups, just in case.
My question is, how can I replace the license plate bracket? I thought about buying a new one from Levittown Ford and simply using bolts to attach to the new inserts as I don't have a rivet gun. Does the primed inserts include mounting holes or will I need to drill?
Or this is another option: http://www.skenedesign.com/FPBracket/index.shtml
What do you all think is the easiest method for attachment? I guess I could have the dealer put it on for me, but can they do it AFTER I put the new inserts in, or should I bring the lower insert piece over to them to install before I put them in?
Just want to know how I should tackle this... Thanks!
P.S. Cellbine, how much of a pain in the ass was it to remove the and replace the inserts? I thought you had done that to PD yours.
  • 1 year later...
