4DOOR2NV Posted July 29, 2013 Report Share Posted July 29, 2013 (edited) Hi everyone, I have a 2010 Ford Edge and I just bought some new wheels that came with TPMS sensors from a 20?? Limited Ford Edge. My question is the new rims I got have black TPMS sensors on them. Does the 2010 have black or blue sensors on them? I've never taken off my OEM tires yet. Just want to double check. Thanks. B. Edited July 29, 2013 by 4DOOR2NV Quote Link to comment Share on other sites More sharing options...
ls973800 Posted July 29, 2013 Report Share Posted July 29, 2013 Make sure you have the correct sensors. I think the 2010 and earlier models used a sensor which was attached to the wheel with a band. The 2011 and newer use a sensor which is attached by the valve stem and a nut. No more bands to go around the wheel. The 2011 and up also use a different frequency to transmit the signal if I'm not mistaken. The sensors in my 2013 are black, I don't know about 2010 or older. Also make sure the wheels you bought aren't from a 2011 or newer. They will not fit your 2010 hub opening unless you have the wheel openings machined larger. Quote Link to comment Share on other sites More sharing options...
