Rear wheel hub/bearing torque specs
dagall
HTH.
FWD
AWD
Installation
All vehicles
  1. Install the wheel bearing and new wheel hub bolts.
    • Tighten to 133 Nm (98 lb-ft).
  1. Position the brake caliper and anchor plate assembly and install the 2 bolts.
    • To install, tighten to 55 Nm (41 lb-ft).
  1. Install the brake disc.
AWD vehicles
  1. Using a suitable installation tool, install the halfshaft into the wheel bearing and wheel hub.
  1. Install the halfshaft hub nut.
    • Tighten to 275 Nm (203 lb-ft).
And a reference for hub/bearing replacement:
http://www.fordedgeforum.com/topic/8329-07-sel-plus-awd-rear-bearinghub-replacement/
Edited by WWWPerfA_ZN0W
