lpgao Posted February 26, 2014 Report Share Posted February 26, 2014 Anybody know how to find your edge powertrain class? I checked lable on my 2011 edge for GVWR, it shows two different numbers for powertrain class I and class II, but how do I know my edge is what powertrain class? How much trailer I can pull with 2011 edge AWD limited? Quote Link to comment Share on other sites More sharing options...
omar302 Posted February 26, 2014 Report Share Posted February 26, 2014 If you have the 2.0 ecoboost engine, the maximum weight that can towed is 1,500 lbs. If you have a V6 (3.5l), it depends, if you have the factory towing package, then its 3,500 lbs. Otherwise it's 2,000 lbs. To know if you have the factory towing package, you should have the factory installed hitch receiver and there will be a setting in the left instrument panel screen for disabling trailer sway control. 1 Quote Link to comment Share on other sites More sharing options...
