jwallace410 Posted April 12, 2014 Report Share Posted April 12, 2014 Earlier this year i was in an accident that involved replacing the driver. Side glass. With the ice we had this winter, i tried rolling down the window and it popped off track. I pulled the door panel and found out that the body shop who did the work failed to set the window properly. On another post id seen that there are rubbe. Grips on the clips attaching to the bottom of the window on the regulator and if thats the case, this shop didnt even use the rubber grips. My question is could i use the same grips vfor the window on my 2011 edge but from an earlier body style. Tryna avoid junkyard hunting and a bunch of running and buying a new regulator priced at. 107$ Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 12, 2014 Report Share Posted April 12, 2014 If you check E-Bay, it seems that window regulators are all compatible for the Edge & MKX for all years 2007 through 2013. See this listing for example for a Motorcraft one: http://www.ebay.com/itm/281307012721 Quote Link to comment Share on other sites More sharing options...
