buffaloedge Posted May 8, 2014 Report Share Posted May 8, 2014 Need your help. I installed the V3 switchback signals for my 2011 edge. After installation, the drivers side front signal wouldnt work right. Now after I installed stock bulbs back in, the left turn signal won't work. Bulbs are good and after putting a meter to the turn signal positive wire, i seem to not be getting power. Anyone know what can cause this? All other lights are working, parking and alll other turn signals. Is there a relay, fuse, etc that would control just this one drivers front signal? Quote Link to comment Share on other sites More sharing options...
akirby Posted May 8, 2014 Report Share Posted May 8, 2014 You might have hosed the smart junction box. Quote Link to comment Share on other sites More sharing options...
ls973800 Posted May 8, 2014 Report Share Posted May 8, 2014 I would at least pull the negative battery cable and wait 10 minutes or more. Hopefully, this might reset something somewhere somehow. Yes, it is just a guess, but I don't think it would hurt anything to try. Quote Link to comment Share on other sites More sharing options...
buffaloedge Posted May 8, 2014 Author Report Share Posted May 8, 2014 Thanks for the suggestion, ls97. I did try that and left it off over an hour. No luck. Akirtby, you mean destroyed the smart junction box? All other directionals are working both front and back. Just drivers side front not working. Put a test light on it and nothing at the socket. Followed wire to just inside the cabin, where it comes in through firewall and no power either. Quote Link to comment Share on other sites More sharing options...
akirby Posted May 8, 2014 Report Share Posted May 8, 2014 Yes - the SJB controls the lights and sometimes it can get confused especially if you're changing something in the wiring. Quote Link to comment Share on other sites More sharing options...
buffaloedge Posted May 9, 2014 Author Report Share Posted May 9, 2014 Akirby, so a dealer can fix this?.Have an appt Monday. Quote Link to comment Share on other sites More sharing options...
akirby Posted May 9, 2014 Report Share Posted May 9, 2014 The dealer should be able to determine if it's the SJB and try to reset it. If you can't find any other obvious wiring problems then that would be the next most likely cause. Not sure what they would charge but they can check it/reset it with their diagnostic laptop. Quote Link to comment Share on other sites More sharing options...
buffaloedge Posted May 9, 2014 Author Report Share Posted May 9, 2014 Thanks for your reply. I need me one of those diagnosis laptops lol. The average person can only do so much with their cars today. Quote Link to comment Share on other sites More sharing options...
akirby Posted May 9, 2014 Report Share Posted May 9, 2014 Those are dealers only. Far too dangerous for most owners. Quote Link to comment Share on other sites More sharing options...
buffaloedge Posted May 10, 2014 Author Report Share Posted May 10, 2014 Agreed! Quote Link to comment Share on other sites More sharing options...
buffaloedge Posted May 12, 2014 Author Report Share Posted May 12, 2014 Turned out that the BCM had to be reset. The car thought there was a short and stopped power from going to the turn signal positive. Quote Link to comment Share on other sites More sharing options...
