Interior grounding stud
tpm419419
If you look at the mount where the emergency brake is held at the lower front of the dash, there are two bolts that attach that metal bracket. It is just over to the left of the OBD port. Its real close the the fuse panel area and up and out of the way. The two bolts are one above the other. I used the lower one.
Thank you RayoVac
I also found 2 studs on the firewall behind the center console that runs a wire through to the engine compartment. If that doesn't provide the ground I will certainly use what you suggest
Thank you again
Edited by tpm419419
  • 7 years later...
