Jamiewedmore1234 Posted June 13, 2014 Report Share Posted June 13, 2014 My 2010 edge sel makes a funky nois and a viberation in the petal when you do your 1st couple of stops in the morning dealer said its common anybody else have this problem Quote Link to comment Share on other sites More sharing options...
Larry Posted June 16, 2014 Report Share Posted June 16, 2014 My 2010 edge sel makes a funky nois and a viberation in the petal when you do your 1st couple of stops in the morning dealer said its common anybody else have this problem Yes I think it is common. My 13 Edge makes the same grinding sounding noise at first braking. I've driven two other 13's , same noise. supposedly hard rotors and pads. Larry Northern,In Quote Link to comment Share on other sites More sharing options...
nickf1011 Posted June 16, 2014 Report Share Posted June 16, 2014 Some "scraping" type of noise is completely normal after the car has been sitting overnight or longer. The rotors are bare steel and will glaze over with surface rust if left sitting in anything other than desert-dry air. Nothing to be concerned about if it's nothing beyond that. The vibration sounds like it could be something more though. Quote Link to comment Share on other sites More sharing options...
SwampDonkey76 Posted August 16, 2014 Report Share Posted August 16, 2014 Is the vibration during hard braking? Do they feel like they are grabbing when coming to a slow rolling stop. If either of these are occurring then you need to have your rotors resurfaced. The vibration is caused by a warpage on the braking surface of the rotors. Quote Link to comment Share on other sites More sharing options...
