Outside air ventilation
Larry
Open the windows
The air coming in the car will always pass over the heater core. If the blend door for the heater is closed (ie set on full cold) but the A/C is turned off, then you will essentially be getting outside air at the ambient temperature. But there is no way to keep getting outside air without running the fan at least at the lowest setting. If you turn off the fan completely, it will close the recirc door.
Open the windows
Yep opening the windows worked. lol I turned on auto temp, switched fan speed to lower speed turned off ac and you are correct , feels like outside air is coming through the vents. No lights lit up on center button.
Thanks
Larry
