e-brake adjustment
Here's what the manual says about the procedure, hope someone with actual experience will chime in:
Parking Brake Cable Adjustment
NOTE: Cable tension is adjusted in 2 locations, the first location is at the parking brake control, the second location is at the parking brake cable equalizer. The tension must be adjusted equally at both locations.
  1. With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-02 .
  1. NOTE: The dimension will vary depending on the amount of cable stretch. New cables require cycling the parking brake control 5-10 times to remove the cable slack.
    Adjust the parking brake control adjustment nut as shown.
07 Edge Parking Brake Adjustment 1
  1. Adjust the parking brake cable equalizer adjustment nut as shown.
07 Edge Parking Brake Adjustment 2
  1. Fully apply the parking brake pedal 3 times to verify correct operation of the parking brake system.
    • With the parking brake cable in the fully released position, brake drag should not be present.
Parking Brake Control/Pedal
07 Edge Parking Brake Control
Item Part Number Description
1 2760 Parking brake control
2 — Parking brake control adjustment nut (part of 2853)
3 W707144 Parking brake control nuts (3 required)
4 2454 Parking brake control pad
5 15852 Parking brake switch electrical connector (part of 14A005)
6 2853 Front parking brake cable
7 — Front parking brake cable-to-control nut (part of 2853)
Parking Brake Cable - Front
07 Edge Parking Brake Cable Front
1 2853 Front parking brake cable
2 — Front parking brake cable-to-control nut (part of 2853)
3 W708004 Front parking brake cable bracket bolt
4 W708004 Front parking brake cable floor plate bolt (2 required)
5 W520201 Parking brake cable equalizer adjustment nut
6 — Parking brake control adjustment nut (part of 2853)
Parking Brake Cable - Rear LH (Rear RH similar)
07 Edge Parking Brake Cable Rear LH
1 W708004 Parking brake cable front bracket bolt
2 W708004 Parking brake cable middle bracket bolt
3 2A635 LH parking brake cable
4 W500021 Parking brake cable-to-support plate bolt (2 required)
5 — Parking brake cable equalizer
6 W520414 Rear stabilizer bar link nut
You can also look here for other repair information. Click on the INFOTRAC url near the bottom of the page, click on PROCEED, then pick your vehicle etc.
Edited by WWWPerfA_ZN0W
Thank you so much WWW, I think the second illustration puts me on the right track. Will just have to get under the vechicle and trace the cable back to the equalizer.Brakes may not be dragging enough to affect anything but I don't like the sound of anything dragging. Thanks again.
