Brake pedal thumping
cph2579
Just got the master cylinder and booster replaced on my 2011 edge. Everything works fine but now when I initially put pressure on the pedal it makes a thumping noise. No grinding or vibration. Only 1 thump. If brake is pressed very gently it doesn't thump. Thump not from slamming on brakes. Happens when using normal pressure.
