krazyteggy Posted December 29, 2014 Report Share Posted December 29, 2014 Is there any way other than a scan tool to remove dash lights? I have abs, traction control and awd wrench lit up. I've replaced the wheel speed sensor (which was the problem) but want to reset the lights to make sure the problem has been fixed..... Any suggestions Quote Link to comment Share on other sites More sharing options...
akirby Posted December 29, 2014 Report Share Posted December 29, 2014 You need an obd-II scanner. Most auto parts stores will do it for free. But they should go away by themselves if the problem was fixed. Quote Link to comment Share on other sites More sharing options...
ls973800 Posted December 30, 2014 Report Share Posted December 30, 2014 Sometimes disconnecting the battery will also clear the light. Quote Link to comment Share on other sites More sharing options...
