INCONSISTENT CLIMATE CONTROL FUNCTION WHEN USING REMOTE START – BUILT ON OR BEFORE 1/31/2013
TSB 14-0038 (supersedes TSB 13-10-13)
Publication Date: February 24, 2014
FORD: 2011-2013 Edge, Explorer
LINCOLN: 2011-2013 MKX
This article supersedes TSB 13-10-13 to update the vehicle model years and IDS version.
ISSUE:
Some 2011-2013 Edge, MKX and Explorer vehicles equipped with factory installed or Ford accessory remote start and built on or before 1/31/2013 may exhibit inconsistent operation of the climate control functions after a remote start event.
ACTION:
Reprogram the heating ventilation air conditioning (HVAC) module to the latest calibration using IDS release 89.02 or higher. Calibration files may also be obtained at www.motorcraftservice.com.
OPERATION DESCRIPTION TIME
140038A 2011-2013 Edge, MKX And Explorer: Reprogram The HVAC Module (Do Not Use With Any Other Labor Operations) 0.2 Hr.
WARRANTY STATUS
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage.
Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
DEALER CODING
BASIC PART NO. CONDITION CODE
19980 04
Ford Module Programming (FMP) is a software application that allows subscribers to program electronic modules on Ford, Lincoln and Mercury vehicles. It can be used for:
•Reprogramming emission-related (OBDII) modules on some vehicles manufactured in 1995 and all vehicles manufactured from 1996 to the present
•Reprogramming or reconfiguring non-emission-related modules on many vehicles (UBP and MS-CAN not supported)
In addition, module initialization (PATS) functions such as Keycode Erase/Reprogram and PCM Parameter Reset can be done using this application.
J2534 Device using Ford Module Programming (FMP) can Reprogram and Configure most Modules.
