ADAPTIVE CRUISE CONTROL – REDUCTION IN SPEED WHEN PASSING A SEMITRAILER TRUCK
TSB 15-0033
Publication Date: March 13, 2015
FORD: 2013-2014 Edge
ISSUE:
Some 2013-2014 Edge vehicles equipped with Adaptive Cruise Control (ACC) may exhibit a concern where the vehicle may reduce speed when the ACC is engaged while passing a semitrailer truck.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Replace the Cruise-Control Module (C-CM). Refer to Workshop Manual (WSM), Section 419-03.
PART NUMBER PART NAME
BA1Z-9E731-C Cruise Control Module
OPERATION DESCRIPTION TIME
150033A 2013-2014 Edge: Replace The C-CM Includes Time To Remove And Install The Bumper Cover And Perform Sensor Calibrations (Do Not Use With Any Other Labor Operations) 1.2 Hrs.
WARRANTY STATUS
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage.
Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
DEALER CODING
BASIC PART NO. CONDITION CODE
9E731 01
