dmozer74 Posted July 24, 2015 Report Share Posted July 24, 2015 I just bought a used 2008 edge limited with the audiophile system. It's lacking in clarity. I added a JL acp108lg and changed out the front speakers for some JL 5x7s. Now I find the system lacking in midbass. I've disconnected the factory sub, and now I'm going to reconnect it to see if it helps. My thought is to find a new 8" midbass driver on a budget, put that in place of the factory sub and have a nicely rounded system on a modest budget. Any thoughts or suggestions on this idea? Quote Link to comment Share on other sites More sharing options...
kkreit01 Posted July 27, 2015 Report Share Posted July 27, 2015 You probably need more power going to your new JLs. Swapping the factory sub for a midbass will gain nothing -- as it's still only going to send the same frequencies that your sub had. I'd think about adding an aftermarket amp to power your front speakers, and power a different sub in the stock enclosure (after beefing it up). Quote Link to comment Share on other sites More sharing options...
