Kuc27 Posted September 2, 2016 Report Share Posted September 2, 2016 (edited) Hi, I've purchased front and rear new rotors and pads for my wifes 2012 Limited. It would be much appreciated if someone could provide me with torque specs... Thanks! Edited September 2, 2016 by Kuc27 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 2, 2016 Report Share Posted September 2, 2016 (edited) this is what the FSM is showing me for 2011, should be same for 2012 (be careful with lb-in vs lb-ft): FRONT Torque Specifications Description Nm lb-ft lb-in Bleeder screw 8 — 71 Brake caliper anchor plate bolts 133 98 — Brake caliper flow bolt 25 18 — Brake caliper guide pin bolts 88 65 — Brake flexible hose bracket bolt 20 — 177 Brake tube fitting 17 — 150 REAR Torque Specifications Description Nm lb-ft lb-in Bleeder screw 8 — 71 Brake caliper anchor plate bolts 133 98 — Brake caliper flow bolt 25 18 — Brake caliper guide pin bolts 88 65 — Brake flexible hose bracket bolt 20 — 177 Brake tube fitting 17 — 150 Edited September 2, 2016 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
Kuc27 Posted September 3, 2016 Author Report Share Posted September 3, 2016 Thanks so much, this is a huge help. I will be installing the max advanced brakes OE rotors and ceramic pads brake kit available from Amazon. The reviews seem to be good and the price is right. I have received the brake kit already and would be happy to answer any questions anyone may have about the kit. 2 Quote Link to comment Share on other sites More sharing options...
