2012 Ford Edge - Rear Camera - No Guidelines
bdshan@gmail.com
My rear camera died so I replaced it with: BT4Z19G490B
The camera works, but I am unable to calibrate it. Using ForScan, the calibration routine gets to 8% then the dash lights flicker and the test fails.
I read all the posts I can find on this issue but nothing that pertains directly to the Ford Edge. Does anyone know how I can get the guidelines back?
Edited by bdshan@gmail.com
I heard back from ForScan and here's what they said:
This is known issue, but there is no known solution yet, According to the logs, the procedure is interrupted by BdyCM. The error code thrown is B115E:08. According to the workshop manual (1.pdf attached) it means Bus Signal/Message Failure. Recommended pin-point test G (2.pdf attached) does hardware part check, but we think the problem is not in the hardware. We have 2 versions (both not checked yet):
1. New camera may be not fully compatible with old BCM. Most likely, BdyCM or APIM firmware update is necessary.
2. If the camera is not OEM ("clone"), it may be not identical to original (OEM) one.
Anyone know how to do the firmware update they are describing?
The software/firm ware I believe will be a Ford proprietary thing and you will have to pay for a diagnostic and update if this is the issue. Is the part a genuine Ford Replacement camera?
