derek_nauds Posted April 22, 2018 Report Share Posted April 22, 2018 (edited) I have a 2011 Edge SEL and the sunroof motor that controls the glass is failing and is sluggish when i attempt to close the glass. The motor works fine while opening the glass but when i go to close the glass its having a hard time pushing it to close, the motor seems like its facing resistance. It's at the point now that i have to manually help it along. Is this just a simple grease the rails problem or is do i need to replace the motor. I've spayed the rails with WD40 but didn't do much to help the glass close smoother, possibly need a better grease or lubricant. Edited April 22, 2018 by derek_nauds Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 22, 2018 Report Share Posted April 22, 2018 (edited) Thoroughly cleaning will definitely help. You can also change the rear roof "legs" if yours are really bad: https://www.tascaparts.com/oem-parts/ford-slide-rail-front-extension-7t4z78502m78a/?c=Zz1ib2R5JnM9c3Vucm9vZiZpPU1XMDc0NzU1JnI9MTQmYT1mb3JkJm89ZWRnZSZ5PTIwMTEmdD1zZWwmZT0zLTVsLXY2LWdhcw%3D%3D Edited April 22, 2018 by omar302 2 Quote Link to comment Share on other sites More sharing options...
derek_nauds Posted April 22, 2018 Author Report Share Posted April 22, 2018 Thanks omar302, I'm going to give this a shot!! Quote Link to comment Share on other sites More sharing options...
