Fuse 44 customer feed accessory
I’m wanting to wire my new dash cam to “ignition on” power and wonder if anyone has used the interior fuse 44 slot that is labeled “Customer accessory feed”? I’m wondering if that slot is ignition on only like I want. I haven’t tested it with a voltmeter yet. Or if you have any other suggestions on which fuse slot to use, I’m all ears.
Thanks, Doug
1 hour ago, viperdoug said:
Thanks I’ll check it out. I’m in the car now with the console cover off looking to see if there is a switched hot wire I could splice into to make the power outlet in the console switched.
I made my rear oulet switchable using a toggle switch hidden under the steering column
