AWD front hub assembly same as FWD?
Hey everyone... I have a 2007 Edge SEL with AWD and need to do my front wheel bearings.... I saw you can get whole hub assemblies which would save me a good bit of money and headache, not needing to get them pressed etc. The only hub assemblies I can find are AWD rears and FWD fronts, none for the AWD fronts for some reason.
If anyone can link me some or knows if this doesn't work for AWD fronts, I would appreciate any help!! Thanks a bunch!!
  • 1004ron changed the title to AWD front hub assembly same as FWD?
Looks like Ford does not sell loaded front knuckles for your generation Edge - so you'll need to either go aftermarket or get the bearings pressed out/in by a shop.  I had to change the front bearings on my Focus, but because I don't have a press either, I just asked the dealer if they could do that if I brought the knuckles down and new bearings, they pressed out/in both front bearings for an hour's worth labor.
1)  https://www.tascaparts.com/oem-parts/ford-hub-assembly-7t4z1104a/
2) https://www.tascaparts.com/oem-parts/ford-front-wheel-bearing-bt4z1215a/
3 - right) https://www.tascaparts.com/oem-parts/ford-knuckle-bt4z3k185a
3 - left) https://www.tascaparts.com/oem-parts/ford-knuckle-bt4z3k186a
  • Thanks 1
Thank you for the help!!
