Marcus Mechanic Posted July 15, 2020 Report Share Posted July 15, 2020 Hello, My fuel door arm is broken so I'm replacing the fuel pocket assembly. I would like to know this is removed? Do I need to take the inner fenderwell loose or are there fasteners or clips that can be released from the outside? Thank you. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 23, 2020 Report Share Posted July 23, 2020 This may not be helpful, I have an 09 MKX, just looked at it and you have to take the inside rear panel off. Then remove the screws from the exterior so that the fuel 'pocket ' assy can be removed. (Removes from inside the car). Your 13 may be different however. Quote Link to comment Share on other sites More sharing options...
