How to Remove Fuel Door Pocket on '13 Edge?
Marcus Mechanic
This may not be helpful, I have an 09 MKX, just looked at it and you have to take the inside rear panel off. Then remove the screws from the exterior so that the fuel 'pocket ' assy can be removed. (Removes from inside the car). Your 13 may be different however.
