PatrickS Posted November 25, 2020 Report Share Posted November 25, 2020 Hi all, Just purchased a used 2019 Titanium Edge (FWD). After a few days of driving, have noticed the rear suspension gives more unpleasant feedback (chatter-y feel and some noise) from road imperfections than either my 2015 Jeep GC or the prior gen Edge that I tested a few years back. I haven't had any success finding tips here on how to settle down the rear. It's both noise and handing, but I think that fixing the handling will solve the noise issue. Was thinking of putting about 50# of rocks in the rear hatch area to see if just needs some weight. If that works, then some weightlifting plates might be a permanent fix. Tires are Hancook. Assuming OEM as the car only has 30,000 miles. Quote Link to comment Share on other sites More sharing options...
fishx65 Posted November 28, 2020 Report Share Posted November 28, 2020 Tires at 32psi will help a lot and adding weight will also help. Weight can be added around the spare under the rear panel. I added a couple bags of tube sand to the back of my Rents 2011 and it definitely helped smooth her out. Quote Link to comment Share on other sites More sharing options...
